Particle Representation Stream
User: "Mrage"
Altair Community Member
Updated by Mrage
i am trying to analyze the movement of particles within a auger tunnel. For this I tried to chose particles representation as stream. But as soon as I choose this kind of reprensentation, the particles disappear. Can you tell me what is the reason for this?
Many thanks and greetings
Leandro
1 - 1 of 11
    User: "Ignacio Diez Alonso (Nacho)"
    Accepted Answer
    Updated by Ignacio Diez Alonso (Nacho)
    Hi Leandro,
    You need to reproduce the animation for the streamlines to show. Since they get generated based on the positions that the particles have in each time-step. So if you press play once you will be able to see them. Hope that this helps.
    Kind regards
    Ignacio
