Developing one model which is basically developed in cad & then importing through step file to flux 3D, while building it for Periodicity & infinite box facing the offset issue can anyone guide here for better clarity attached screenshot
Hi Dattu B. Pawar,
You need to create a coordinate systems for which you specify the offset angle and when importing the 3D model you specify the created coordinate system.
Best regards,
Alexandru
Hi Dattu;
In the periodicity you created, if you edit it again, you can make and offest angle. You have to know in advance this angle.
Regards
Thanks, error resolved
Hi Dattu B. Pawar, You need to create a coordinate systems for which you specify the offset angle and when importing the 3D model you specify the created coordinate system. Best regards, Alexandru
Thanks Error Resolved
