Please guide how to create coordinate system & place armature coils for axial flux ACG in flux 3D
In this case, select in data tree, geometry >> geometry tool.
In Flux supervisor example, there is an example about the axial flux motor:
Flux supervisor >> Flux 3D >> open example >> application note: select axial flux motor. Pen the case Back MEF.
You can check this example to see more in depth how we create non mesh coil using coordinate system.
Best regards.
Hi, In this case, select in data tree, geometry >> geometry tool. In Flux supervisor example, there is an example about the axial flux motor: Flux supervisor >> Flux 3D >> open example >> application note: select axial flux motor. Pen the case Back MEF. You can check this example to see more in depth how we create non mesh coil using coordinate system. Best regards.
Thanks fo ryour reply Abdesssamed, I checked with example from Flux supervisor, I couldn't get how to create coordinate system & nonmeshed coils in that, Could you please guide further in this. thanks again
You are welcome.
In the example, if you select the case 2, there is a python script on which there is a command used to create the coordinate system and non-meshed coil
\Altair\flux\Flux\DocExamples\Examples3D\Application_Note\AxialFluxMotor\AxialFluxMotor\AxialFluxMotor_3D_Case2
To create your non meshed coil:
See attached file.
