🎉Community Raffle - Win $25
Join and Win
Print in batch mode
User: "omartin"
Altair Community Member
Updated by omartin
Hello, I am running a script in batch mode on Hypermesh 2019 and I would like to print everything the program is doing instead of 'Ready' and then close. This is what I have but doesn't seem to print anything:
xxx\altair\v2019\hw\bin\win64\hw.exe -b -p mvw_file -tcl script.tcl
1 - 4 of 41
    User: "omartin"
    OP
    Updated by omartin
    I just want the black window of Hypermesh batch mode to show what it is doing.
    User: "tinh"
    Updated by tinh
    If you want, in your tcl file: create a tk toplevel and a textbox to puts ouput status there
    User: "Vlad VB"
    Updated by Vlad VB
    Tinh,
       Do you have example of toplevel textbox that can output status? Thank you
    User: "tinh"
    Updated by tinh
    sample like this:
    package require Tk
    set w [toplevel .output]
    wm title $w 'Output status:'
    set t [text $w.t]
    pack $t -fill both -expand yes
    #output everything you need:
    $t insert end 'script is running at stage #???'
    Another way, easier, you output status to a text file, as almost FE solvers do (nastran outputs to f06, optistruct outputs to .out , dyna outputs to d3hsp...):
    set fpt [open output.txt a]
    puts $fpt 'script is running at stage #???'
    close $fpt
    use tail.exe to see the newest message
