For holes and slots it´s easy to add washers and refine the surrounding mesh. How can I add such washers to the radii in my outer contours with the batch mesher?
This option does not exist in BatchMesher.
If you want this pattern, you might have to use the Line Offset tool
Thank you, this should be the best solution.
