Hello, I try to create output accelerometer But the result is so bad, I don't Know What is The Problem, Can you help me pls ??
Thanks and best regards
Your curves seems defined as AX-X Acceleration/AX-X, AX-X Acceleration/AY-Y, AX-X Acceleration/AZ-Z. I'm not sure if my suggestion will match what you want. But if you want Time versus AX-X Acceleration curve and others, could you please define X Type as time in the interface.
Best Regards
Tayfun
Hello, Your curves seems defined as AX-X Acceleration/AX-X, AX-X Acceleration/AY-Y, AX-X Acceleration/AZ-Z. I'm not sure if my suggestion will match what you want. But if you want Time versus AX-X Acceleration curve and others, could you please define X Type as time in the interface. Best Regards Tayfun
Thanks, I got it,
