HX Solver error code: "INTERNAL ERROR PH155MEMPAK"
Updated by NarendraSingh
I ran a simulation and solver crashed with following error message. What does it mean?
Simulating extrusion of a single hollow profile *** INTERNAL ERROR PH155MEMPAK Maximum memory used: 2157101 KB
This error can come due to following reason,
- 1) If mesh in bearing and profile component is bad. Check if mesh in bearing and profile component is properly dragged in the extrusion direction.
- 2) if Freesurface start location in .hx is not defined correctly.
How to overcome?
- Option #1:
- Check mesh in Bearing and Profile component. if you are running polymer extrusion then check mesh in Land and Profile component.
- Check if mesh in bearing and profile component is properly dragged in the extrusion direction.
- Option #2:
- check what is start Z location of Bearing solid
- open .hx file and review value for Freesurface pset variable. it should match bearing start Z location.
No comments on this post.
