Help on some functions in Activate and Compare coupling simulation
yugang
yugang Altair Community Member
Currently we use activate for multi-physics simulation in our daily works about product design. But there are some very useful functions. For example
bdeGetModelFilePath(…)
vssRunSimulation();
 I want to know where I can find the help or documents about this function, is there any documents about its definition, or how to use it.
I have tried in activate, compose, I don’t get any information.
Thanks.
Welcome!
  • RoKet
    RoKet
    edited October 2020
    Hi yugang,
    Unfortunately there is no written help for many functions. It's on top of the todo list (but often other things get a higher priority :( )
    vssRunSimulation is an oml function (file vssRunSimulation.oml), explanation of parameters is in this file:
    function scs_m=vssRunSimulation(model,context,workspace,simobject,raiseerror,allowSimObjectCreation,reinitfunc)
    This function is used to run the simulation of a given model.
       model: optional argument. If omitted, it is the current model.
              It can be:
                a string the filename of the model.
                a model pointer.
                an empty matrix. if the simobject is defined it is the model in the simobject, else the current model.
       context: optional argument. if omitted, it is an empty struct (default).
              It can be:
                a struct.
                an environment.
                an empty matrix, means default.
       workspace: the workspace where the simulator will read/write the signals. if omitted, the workspace is the base environment (default).
              It can be:
                an environment.
       simobject: the simulation object used by the simulation, if omitted it will be created if the allowSimObjectCreation is true (default).
              It can be:
                a simulation object pointer.
       raiseerror: Boolean, if true the function will not popup an error dialog if the simulation object is defined, else it will throw an error. default value is false.
       allowSimObjectCreation: Boolean, if true the function will create the simobject if the simobject is not defined. the default value is true.
       reinitfunc: string, the function that the compiler call after evaluation. Default value: empty string
    bde-functions are internal functions, it's difficult to find a declaration.
    bdeGetModelFilePath() is often used in Activate scripts, e.g.
      modelFilename = bdeGetModelFilePath(bdeGetCurrentModel());
      curmodelpath = fileparts(modelFilename);
    fileparts returns the directory, name, and extension components.
    Best regards
  • yugang
    edited October 2020
    Hi yugang,
              It can be:
                a model pointer.
              It can be:
                a struct.
                an environment.
              It can be:
                an environment.
              It can be:
    Best regards
    Ah, it could be a problem. Because sometimes we might don't know this function exists ...
    For example, we can use VssRunSimulation(), to call activate for simulation model.
    This function is told to me by my French colleague.
    If he did not tell me, I might not ever to discover this function. Since no way to find it ... as it not exist.
  • RoKet
    RoKet
    edited October 2020
    yugang said:
    Yes, same with me. And there are so many functions ...
    It's always a help for me to look at scripts in demo models, tutorials, and other stuff to get an idea of some (unknown) functions.
Welcome!
Welcome!
