Hello to everyone,which material curve should I use for a nonlinear analysis?Engineering or true curve?Do I have to use any tricks?thanks in advance
just remember that the stress x strain curve is input in Pascal.
I found that you can also define it as true stress curve, by adjusting the header of the csv file, in case you import it.
