How to Export .log file of cfd results ( Velocity, pressure, etc ) to single H3D file that should contain all results type.
If you're using HyperMesh CFD, you can use the Convert tool from the Solution ribbon. You can indicate Output Format H3D and Data Type Nodal Output (Extended) to see all available variables, then select which of those you want to write into the H3D file. There's a toggle for H3D Options - multi file or single file.
Thank you , i will check these options
