I just checked out composite tutorials and it is written that "The ply thickness is typically defined as the final cured thickness of a single ply of material."
How can I combine reinforcement / matrix properties and thickness then import as mat8 prop and ply thickness? I mean does it make sense that I assume 1mm thickness as 0.8 mm reinforcement and 0.2 mm matrix and just assign carbon fiber probs?
I am newbie on composite analysis, thanks for helping.
