Altair RISE
Nominate Yourself Now!
Coil Efficiency
User: "jerometeoh917"
Altair Community Member
Updated by jerometeoh917
Good morning,
I have a question about how to calculating the efficiency of coil in 2D and 3D model in Altair flux?
I think we should start with using the 'compute on physics entity' function to do it but what to use?
Active power? or Joule losses? Is that matter for coil and substrate region?
Also, for total power of the multiple-turn coil: Total power = total sum of power from all the regions?
Should I account the negative and positive sign cancel out each other?
Jerome.
1 - 1 of 11
    User: "asoualmi"
    Accepted Answer
    Updated by asoualmi
    To compute the efficiency on the coil you need to use Joule losses. In Flux to compute the active power the formula used is Active_power= V*I, for the Joule losses the formula uses is Joule_Losses= R*I*I (in this case you take the total current in the coil).
    Best regards.
