When attempting to run a CFD simulation in Hyperworks Virtual Wind Tunnel 2019.2, the run almost immediately fails with the following dialog message: Timer stopped because of 'JOB_UNKNOWN_STAGE'. When looking at the file directory for the run, the only file generated is the AnalysisHistory.info file, which reads:
# -------------- Virtual Wind Tunnel Analysis History Information ------------
# This file contains the history information of virtual wind tunnel analysis
# NOTE: DO NOT DELETE THIS FILE IF HISTORY TO BE LOADED IN FUTURE
Client = Inspire 2019 19.2 11125
Name = Full_Vehicle_CFD_Model_v11_run5
WorkingDir = /home/thavema/Documents/HW/2019/vwt/Full_Vehicle_CFD_Model_v11_run5_9-8-2020_18-36-22
ModelName = Full_Vehicle_CFD_Model_v11
GroupId = 1
StartTime = 9/8/2020 18:36:29
CompletionTime = 9/8/2020 18:36:35
ElapsedTime = 00:00:02
Status = 6
PercentComplete = 100.000000
#END RUN HISTORY ---------------
I was thinking that this might be an issue of not enough computing power because it is a large model. Has anyone run into this issue before?
Thank you so much for your help!
