I want to model and simulate the cross-coupling between Tx and Rx of TEM horn antennas.
Since the cross-coupling is unintentional and the Rx antenna is off-bore sight,how can i model it ?
Is that possible by S21 or received power ?
Note:- The purpose of the Rx antenna is to receive reflected signal from the ground and the Tx and Rx are operating in bi-static mode.
Tx and Rx are near to each other.
Tx----------Rx
