Unintentional Cross-coupling
ዘካርያስ
ዘካርያስ Altair Community Member
I want to model and simulate the cross-coupling between Tx and Rx of TEM horn antennas.
Since the cross-coupling is unintentional and the Rx antenna is off-bore sight,how can i model it ?
Is that possible by S21 or received power ?
Note:- The purpose of the Rx antenna is to receive reflected signal from the ground and the Tx and Rx are operating in bi-static mode.
Tx and Rx are near to each other.
Tx----------Rx
  • Smitha Ramaiah
    Smitha Ramaiah Altair Community Member
    edited June 2020
    Model two(one Tx and Rx) horn antenna in different angle say one is in x-direction and other is in -x direction with certain distance by placing the ground.
    Terminate one antenna by load and excite other antenna by wire port.
    S-parameters can be found
    Thank you
