Hi all,
How can i set a dielectric medium in TEM horn antenna i.e. in the free space between upper and lower conductors (as we know a dielectric can only be applied in closed regions) ?
You should be able to achieve this by setting the required geometry faces to have their 'Face medium' as 'Dielectric boundary'...
For example:
The same process can be applied to your horn antenna geometry by first creating it as a solid (filled) geometry, setting the internal medium and then setting the required face properties.
Kind regards,
Johan H
