Hi..
I am simulation a double cage induction motor .. i am getting the following error during solve.
External arc axes and the rotation axisof the mechanical set ROTOR are different.The mechanical set rotation is impossibleConcerned line(s) : 944
Please guide me. corresponding pictures are attached.
Hello;
Can you please split the airgap on two region. One wille be fixed airgap, and the second one surrounding the rotor regions will be mobile one.
You can have a look on the tutorials available from the supervisor so you can see how it is made.
I hope this will help you
Best regards
Thanks
It helped a lot ..It works..
You are welcome !
