Hi,everyone,
Recently, when using Hyperstudy to call Ansys Workbench for optimization, I encountered a problem: how to constrain a variable to be less than or equal to another variable?
For example, how to constrain die_t to be less than medel_t,I use links to set var_3<=var_4, but keep reporting errors.
How can I achieve this goal?
Thanks。
Amasker,
You rather need an input constraint.
