How to review Elastic property Value of Spring Element
Hi everyone, I have just created several spring elements with K=1.05 (Elastic property Value).
I want to review Elastic property Value (K) of these spring element but impossible.
How to review Elastic property Value of Spring Element?
Thanks everyone!
Dear @Q.Nguyen-Dai
My CARD Image is PELAS, after I created Spring Element. I want to re-check K factor but still not yet.
I also use REVIEW option of spring but I only see dofs.
Review panel on element gives you DoF.
Review K value, you have already 'Property editor', not on Element panel.
Where is 'Property Editor' in HyperMesh?
Please teach me.
When you click on a Property within 'Model view', you see 'Editor' below:
When you define your Spring, you does not give directly K value into element definition, but you link this element to a Property (PELAS in your case)
Tks @Q.Nguyen-Dai
Now I want to check K value of a element. I choose element and I want to know K value of that element.
Because I have 3 Kx,Ky,Kz for a couple node. So I want to re-check
Best Regard
What do you do to create this Spring element?
I think the way: Mesh -> Create -> 1D Element -> Springs -> ...., right ?
Dear @Q.Nguyen-Dai
Yes, I made as your thinking.
I have just found answer for my question. When I review panel on element gives me DoF, it also give me the PROPERTY of element which I make review.
It's right as you said, Value was linked element to a Property (PELAS in your case)
Thanks @Q.Nguyen-Dai very much for your support/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Dear @Alex Nguyen Can you please describe how to create 3 spring elements at one location so as to define Kx, Ky, Kz for one particular location?
THanks in advance
Which CARD image do you use for Spring property?
