Create MPC for 3D element
User: "Alex Nguyen"
Altair Community Member
Updated by Alex Nguyen
Hi everyone, Now I have a problem deal with create MPC for 3D element.
My components include 2 parts fix together (bolt and plate). At thread match position, I want to create MPC connection between thread and hole
But it apprears error ' DOF on grid 704 appears twice in equation, please modify dof selections'. Whether I made MPC connection rightly or not?
Thanks guys
1 - 9 of 91
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    What's your final goal of using MPC?
    User: "tinh"
    Updated by tinh
    He is doing homework about mpc, i think so!
    Alex, Could you take photo of mpc definition? Dofs & nodes?
    User: "Alex Nguyen"
    OP
    Dear Mr. Tinh and Mr. Q.Nguyen Dai
    I have a assembly structure between bolt and hole. My mission has to connect them together by match node and MPC node. (green line in below figure)
    Weight factor of Dependent node= -1 and Weight factor of Independent = +1 for each DOF
    But after I create mesh bolt and hole (ensure match node), then I create MPC, and MPC warn that ' DOF on grid 704 appears twice in equation, please modify dof selections'
    I also wonder why need create MPC while these nodes ( between bolt and hole) were matched together (coincident node). Or maybe because these nodes were matched together so MPC can not created?
    Thank so much Mr. Tinh and Mr. Q.Nguyen Dai
    :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    User: "tinh"
    Updated by tinh
    Yeah, i understand.
    2 nodes are concident => so you cannot pick them separatedly.
    You pick n704 as dependent, and then pick overlapped one as independent but hypermesh catches n704 so n704 was selected for both dep and indep=>
    Press O to enter panel Options>graphics> activate 'concident picking' and try again.
    Are you sure there are 2 nodes ? In case you equivalenced them (shift F3), you have to detach (panel 3d>detach)
    If you shared nodes (equivalenced), you don't need mpc because there's only 1 node.
    You did not answer question of @Q.Nguyen-Dai ?  I want to know your goal, too.
    User: "Alex Nguyen"
    OP
    Thank you Mr.Tinh
    Yeah, I understood.
    I'm very sorry for forget answer question of @Q.Nguyen-Dai. My goal of using MPC is calculate Nonlinear Static Structure( stress, displacement, deformation). Really I also only know that much.
    I'm be grateful Mr.Tinh so much. I remember this is third time you support me about MPC problem:D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />. Thank you so much
    Best regard @tinh and @Q.Nguyen-Dai
    User: "Altair Forum User"
    Updated by Altair Forum User
    Hey. I'm experiencing the same problem. I was trying to resolve it somehow, but I wasn't lucky.
    oh... I have the same problem. really. I don't know what to do
    User: "Alex Nguyen"
    OP
    HI @matthampton and @DawnPeterson
    As above tutorials, You should not equivalence 'couple nodes'. Make ensure that One node in number ID is 'a', and another node which number ID is 'b' .
    You let try. I had finish it.
    Thank you everyone
    Best Regards
    If you are looking for the essay writing service and Aerospace Engineering Assignment Help then you should definitely go for AllAssignmentHelp.com. We offer all types of subjects assignment helps at the best price.
