Here is my issue: I want to change the mesh of a given part of interest in my model (green). I re-meshed it and now I would like to manage the interaction between my new mesh and the coarse mesh (grey) of the parts in contact with it (cf. screenshot).
I have been advised to use an INTER/TYPE2 interface. I tried to implement it but I didn’t succeed.
Should I take my part of interest (green) as master surface (Surf_id)? The tool proposes to select it by elements/set/component. The “by elements” option only works with shell elements, that I don’t have originally in my model.
For the Grnod_id (S), the selection by nodes works.
Also, which parameters would you recommend for this INTER/TYPE2? (Are the 0: default values ok for this kind of application?)
Thank you for your help.
