I'm trying to install and use FEKO on a Ubuntu machine. I've successfully installed in and run ". initfeko" and I'm getting this error when I try to run "cadfeko":
_______________________________________________________________________________________________________
QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: linuxfb, minimal, offscreen, vnc, webgl, xcb.
Aborted (core dumped)
Can anyone help?
Thanks!
- Spencer
