I want to select only 2d components from an assembly file
by 2D component you mean geometry with surface only, or do you mean components that have 2d elements only?
if it is elments, you could use:
*createmark
"by config" configsPlace entities on mark_id if they are of the specified config.All element and load config names/IDs are valid.
*createmark elems 1 "by config" tria3 tria6 quad4 quad8
