Apply Enforced Displacment
Altair Forum User
Altair Forum User
edited March 2021 in Community Q&A
Hi there,
I'm new at Hypermesh and I was wondering how to apply an enforced displacement as BC?
I've created a load collecter for my 'normal' constraints, and another one for my SPCD constraints, where I put dof3 on 25 for a displacement of 25mm. I've read, that I have to create another SPC with the same settings as the SPDC. But How do I merge the constraints for the SPC loadcase? And when I apply the SPCD constraints and the SPC constraints with the dof3 setting then following error appears:
  *** ERROR # 176 ***
  A dependent d.o.f. of rigid elements is constrained in an SPC set.
Can someone help me?
  • Altair Forum User
    Altair Forum User
    edited April 2015
    Hi Xone92,
    Looks like you are applying an enforced motion on a dependent node of rigid element which is not allowed.
    SPC should be applied on the same node as SPCD with same DoF checked as marked for SPCD.
  • Altair Forum User
    Altair Forum User
    edited April 2015
    Ah Nice! Thank you! That was the problem image/emoticons/default_wink.png' alt=';)' srcset='/emoticons/wink@2x.png 2x' width='20' height='20'>
  • Altair Forum User
    Altair Forum User
    edited May 2017
    Hi prakash
    Can you shared me any of the example model of enforce displacement. Which is to define the displacement in SPC.
  • Altair Forum User
    Altair Forum User
    edited May 14
  • Altair Forum User
    Altair Forum User
    edited May 2017
    grear thanks prakash.
    I am facing lot of problem with press fit analysis. If possible do have any example model please share me....
  • Altair Forum User
    Altair Forum User
    edited May 2017
    @dineshreddy
    I think already an example was shared with you. What problems are you facing?
    Let us know about the problems and we will try our best to help you :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
  • Altair Forum User
    Altair Forum User
    edited May 2017
    Hi prakash,
    Is there any example model which we can apply self + acceleration  load case. How can we apply that and genrally it is for Trim  component.
  • Altair Forum User
    Altair Forum User
    edited May 2017
    Hi Dinesh,
    can you explain what do you mean by Self+acceleration?
  • Altair Forum User
    Altair Forum User
    edited August 2017
    When I want to import fem file into hypermesh, I am receiving this error:
    The file specified is not a Hypermesh database
    How can I import fem file into hypermesh?
  • Altair Forum User
    Altair Forum User
    edited August 2017
    you need .hm file fo that.
  • Altair Forum User
    Altair Forum User
    edited August 2017
    How can I open fem file in hypermesh?
  • Altair Forum User
    Altair Forum User
    edited May 14
    I want to apply four displacement boundary condition to the attached model in hypermesh (I am working in Optistruct). Please, help me out or explain how I can achieve it:
    x_disp = x displacement
    y_disp = y displacement
    x_coord = x coordinate
    y_coord = y coordinate
    1. (x_coord = 100, y_coord = 35), (x_disp = 2.754, y_disp = -2.345)
    2. (x_coord = 100, y_coord = 40), (x_disp = -3.754, y_disp = -1.345)
    3. (x_coord = 15.3, y_coord = 100), (x_disp = 1.34, y_disp = 2.345)
    4. (x_coord = 15.3, y_coord = 13.4), (x_disp = 2.34, y_disp = 1.345)
    Thank you.
  • Altair Forum User
    Altair Forum User
    edited August 2017
    Hi Samuel,
    Some of the coordinates which you specified are no where near the structure. Please check
    Anyways you can use specify enforced dispalcement using SPCDs. Please search for SPCD/enforced displacement on forum for related posts.
  • Altair Forum User
    Altair Forum User
    edited August 2017
    I still do not understand. Could you please help add enforced displacement (-0.167, 1.234) on the node at the upper right corner of the model. Alternatively, briefly explain how to locate the node and how to apply such enforced displacement
  • Altair Forum User
    Altair Forum User
    edited August 2017
    This is the new error when I attempted to use enforced displacement:
    *** ERROR # 186 ***
     An SPCD component must be constrained by an SPC or SPC1 data.
          GRID ID = 33
        component = 3
      LOAD set ID = 7
       SPC set ID = 1
       subcase ID = 1
  • Altair Forum User
    Altair Forum User
    edited May 14
    Constrain SPCD nodes with SPC with same Dofs as SPCD.
    Here is a test file
  • GHASSEN BEN-AMOR
    GHASSEN BEN-AMOR New Altair Community Member
    edited March 2021
    To open fem file, you have to go to File -->import -->solver deck ;)
