hello,
i am working on a monocoque chassis and to start my analysis i wanted to simulate a perimeter shear test in hyperworks.
i have made a model with a surface and shell elements . the model is attached below.
the test involves applying constraints to the lowest surface and load on the topmost surface.
is it fine to apply fixed support on the surface excluding the lower 32mm dia circle and apllying force on the upper 25mm dia circle region.
please help it is very important for me.
