import fem file
Hey guys,
I have a problem importing fem files into hypermesh. Somehow, nothing appears whenever I click import. The file is fem and I'm using optistruct. I want to view the results of the optimization once it was finished in hypermesh.
Any help?
Thanks!
You must be in the correct template before importing the .fem file.
If you are in the wrong template, although you select to import bulk data fem file, there could appear some error.
0 -
Hi! Thanks for replying! How would I change a template? Is a template the same as user profile? I made sure that I'm using optistruct for my user profile and am in Hypermesh when importing the fem file. But, it's still not working /emoticons/default_sad.png' alt=':(' srcset='/emoticons/sad@2x.png 2x' width='20' height='20'>
Does this importing fem file received from an optimization (using optistruct) only works for hyperworks 11 and not 10?
0 -
Describe/post (part of) the content of the .fem you want to import.
0 -
Hey here's part of the fem file
$$ Optistruct Input Deck Generated by HyperMesh Version : 10.0build60
$$ Generated using HyperMesh-Optistruct Template Version : 10.0build60
$$ Template: optistruct
CSTRAIN(H3D,ALL) = YES
CSTRESS(H3D,ALL) = ALL
OUTPUT,FSTOSZ,YES
$$ Case Control Cards $
$$ OBJECTIVES Data
$HMNAME OBJECTIVES 3objective
DESOBJ(MIN)=12
DESGLB 2
$HMNAME LOADSTEP 2'battery' 1
SUBCASE 2
SPC = 11
LOAD = 1
WEIGHT = 1.0
$HMNAME LOADSTEP 4'rollbars' 1
SUBCASE 4
SPC = 11
LOAD = 4
WEIGHT = 1.0
$HMNAME LOADSTEP 5'suspension' 1
SUBCASE 5
SPC = 11
LOAD = 9
WEIGHT = 1.0
0 -
facing the same error in HM 2023.1 even when trying to import a batchmeshed FE file
