I'm using the latest script version of AoR test script and present de following error:
The resoults that i'm try processing are from EDEM 2021.1 and the script is from EDEM 2021.2 instalation
Thanks
Hi Joshua, I believe this is due to a change in EDEM 2021.2 where the 'creatordata' value is now indexable. If you replace any instances of this with creatordata[0] then this should resolve the issue you see.
You can replace with any other value than [0] depending on which time-step you want to get the information from the creator, however at start time is most common.
Regards
Stephen
That information was correct. Thanks a lot.
