Error importing Antenna Magus Antenna
Hi.
I made an antenna with Antenna Magus and get *.cfx file from it. I exported it for FEKO.
When i open this file with FEKO its OK and working as it should.
But when i try to import this file from a CADFEKO project, i get this error:
Critical Error CADFEKO 2017.2.4-315226 (x64) src\cf_ProjectAutomation.cpp (117): Assertion failed: 0
And FEKO immediately close itself.
I want to simulate multiple antennas so i need to import several of them in one project so it must be imported, not open with CADFEKO.
How can i do this?
Hello mustaphos,
This is a known problem that we recently discovered. There is an easy workaround. Open the model in CADFEKO and then simply click on save - no need to change the model (maybe just mesh so that the model has a change). The model that you now saved can be imported.
The reason for the error is that there is some special code to allow Magus to create CADFEKO models and this is causing problems during the import.
0 -
Hello all,
I am using CADFEKO v2022.3, and when I'm trying to import a .cfx file, I am getting a similar critical error:
I've saved the model, as it has been suggested above, but nothing worked. Have you got any suggestion, please?
Many Thanks,
Ana
