How to check element type using TCL commands
User: "Altair Forum User"
Updated by Altair Forum User
Dear all,
Could you tell me how can I obtain ANSYS element type in HyperMesh using TCL commands?
My target is to put element type name into a variable.
The procedure using graphical interface is following: 2D/3D -> element types -> mark element -> review. (result on the figure)
Is it possible to extract such information from particular element by a TCL command?
I've tried by hm_getentityvalue but got stuck on data_name format.
Best regards
Jakub
1 - 2 of 21
    OP
    Try this code:
     *createmarkpanel elems 1 'Select Elems' set elems [hm_getmark elems 1] *clearmark elems 1  foreach eid $elems { 	set typename [hm_getentityvalue elems $eid typename 1] 	puts [format 'Eid %6d ; Typename= %s' $eid $typename] }
    HTH,
    User: "Andrew_22514"
    Altair Community Member
    Updated by Andrew_22514
    Try this code:
    HTH,
    Looks like this still works in HyperMesh 2021.2 but it is not listed in the Tcl Query Commands reference page, which I assume means it won't work very soon. Does anyone know the current way to do this command in HyperMesh 2021?
    Found it:
    Use hm_getvalue
    Example: Find the type of the element with id=9298, which in my model is a CQUAD4 element for NASTRAN:
    set elem_id 9298;
    set elem_type_name [hm_getvalue elems id=$elem_id dataname=typename];  # Returns: CQUAD4
    set elem_type_id [hm_getvalue elems id=$elem_id dataname=type];  # Returns: 1
    I'm not sure how that 1 in the last command corresponds to the values found using the ``
    hm_getentityvalue elems $elem_id typename 1`` command....
    See also: elements data name for HM2021
