I see the command '*filewritecomponentgeometry' :
*filewritecomponentgeometry - This command allows you to export HyperMesh files on a per-component basis, so that you can export HM geometry that is part of a larger assembly without exporting the entire assembly.
I'm looking for another command allowing to export also meshing & geometrical data of one component into a HM model ?
Any idea for help ?
Thanks,
