I want to fix the body to the ground.How can I fix the body to the ground in motion solve?
Hi Prashanth,
You can use a fixed joint to fix the body to the ground.
Hi Prashanth, You can use a fixed joint to fix the body to the ground.
If I use a fixed joint then I would not get the correct motion.
