I'm working on a model in Abaqus. For pre-processing I'm making use of Hypermesh. The abaqus file gets imported into hypermesh properly. But when I create new 2D elements, change material properties and component names and export it back, it fails to get imported properly in abaqus. All the components have been assigned with right properties. Is there something else I'm missing.
Pls find the error while trying to import in Abaqus below:
The model 'C56_Atemp_2D_ELEMS' has been created.
AbaqusException: in keyword *MATERIAL, file 'C56_Atemp_2D_ELEMS.inp', line 52330: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): model
in keyword *ELASTIC, file 'C56_Atemp_2D_ELEMS.inp', line 52331: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): material
in keyword *MATERIAL, file 'C56_Atemp_2D_ELEMS.inp', line 52334: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): model
in keyword *ELASTIC, file 'C56_Atemp_2D_ELEMS.inp', line 52335: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): material
in keyword *MATERIAL, file 'C56_Atemp_2D_ELEMS.inp', line 52338: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): model
in keyword *ELASTIC, file 'C56_Atemp_2D_ELEMS.inp', line 52339: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): material
in keyword *MATERIAL, file 'C56_Atemp_2D_ELEMS.inp', line 52341: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): model
in keyword *ELASTIC, file 'C56_Atemp_2D_ELEMS.inp', line 52342: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): material
in keyword *MATERIAL, file 'C56_Atemp_2D_ELEMS.inp', line 52344: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): model
in keyword *ELASTIC, file 'C56_Atemp_2D_ELEMS.inp', line 52345: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): material
in keyword *MATERIAL, file 'C56_Atemp_2D_ELEMS.inp', line 52347: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): model
in keyword *ELASTIC, file 'C56_Atemp_2D_ELEMS.inp', line 52348: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s): material
