   I'm simulating a reluctance motor but I found a trouble during the simulation.
   I splitted the airgap in two several airgap. The first one is associated to the rotor, the second one to the stator.
   So I imposed the first one with a mechanical set kind of ROTOR (rotation around one axis).
   The second airgap associated to the Stator has been characterised with a mechanical set kind of STATOR (Fixed).
   When I try to start the simulation an error appear:
   External arc axes and the rotation axis
 of the mechanical set ROTOR are different.
 The mechanical set rotation is impossible
   How can I solve it? In the picture you can check the model
