I am finding trouble running the simulation with this part. Due to almost zero thickness in the screw thread region, I set the element size with 0,13 but it keeps running for hours, I left more than 48 hours and it did not completed, actually the bar doesn't change its position.
I also tried with element size as 0,3mm and couldn't complete the simulation. I need a small element size like this because the gate point that was defined. Here below in the images are some of the errors I found.
I am sending the icast file for your reference. in advance I thank you for your support.
Please help understand if I am doing something wrong or there's a problem with my computer
or with software installation.
In advance, thank you for attention and support.
