I want node id colour as black in image.Kindly help.
Query>>node id>>select node(by default it is in white).I want this in black.
Thanks in advance.
Hi Mohan,
It may not be possible to change the color of the label from GUI.
But, as a workaround you can use Notes panel in HyperView to attach labels (node IDs to nodes) with different color.
6y too late, but I guess you can use Tools>Create>Tags to do this action.
