No stresses in .mnf created from H3D
Altair Forum User
Altair Forum User
I'm using HW8SR1 for converting H3D in to MNF be used with ADAMS/FLEX.
H3D file is generated using .fem of optistruct and with stress recovery option 'ON'.
flex-H3d also shows the relative stress / strain information when opened in Hyperworks. But when converted to .mnf (using HYPERVIEW --> FlexTools --> FlexPrep) , the file doesn't carry the stress information.
Is it the standard problem? If yes what is workaround.
If no, does it require any parameter setting ?
  • Altair Forum User
    Altair Forum User
    edited December 2007
    Hi, I'm Keshav replying here.Can you please share the h3d file with me? Please mail mvsupport@altair.com with the h3d file. I'll take a look at the file and will get back to you. Thanks.
  • Altair Forum User
    Altair Forum User
    edited December 2008
    I also face the same problem, could you share the information here instead of PM? That the use of forum right?to share information and discussing problem.
  • Altair Forum User
    Altair Forum User
    edited September 2011
    as i know you need grid point stress values for mnf creation, you must put the card gpstress in your fem file and solve it again:
    GPSTRESS(ALL) = ALL
    element stress/strain values could be used for fatigue analyses
    here is a small bat file which you could edit and use for your files:
    set FLEX=C:\Altairwin64\hw10.0\io\translators\bin\win64
    %FLEX%\flexprep your_file.fem your_file.h3d CB +node+node+node+... nm -STRESS -FEMONLY -PURGE -MEGAGRAM -MILLIMETER -NEWTON -SECOND
    definition:
    set FLEX=C:\Altairwin64\hw10.0\io\translators\bin\win64 sets the path of flex_prep utility
    CB means usage of craig-bempton
    +node+node+node+... means your interface nodes
    at the end of the interface nodes there is a value nm (you could change it) it means number of modes
    and the last part is easy to understand image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
  • Altair Forum User
    Altair Forum User
    edited February 2012
    Hi Hexagon,
    That was a great response. I learned a lot, thank you!
    I recently started using MotionView 11 (SA-101) and I don't have these problems, so I guess the Altair folks must have resolved the issues..
    Syairasm & BSG,
    Hi! I'm a newbie to this forum.. May I know for what applications do you simulate using Multi-Body Dynamics?
