hi,
i want to optimize 1 D Truss in Hyperstudy, but i can only see material and force in Design Variablen (ich want to change r_i radius).
wilch card can i change in Hyperstudy, that i can see Design Variablen (r_i radius) in Hyperstudy.
thanks!
What is your solver?
I have the same problem. I want to optimize a 1D Truss, but as I try to import the variables I have only Materials and Force as Model Parameters. What I need is the radius or the area I set in HyperMesh as propertie. My solver is Optistruct.
You can use the 'parametrized input file' model in HyperStudy instead of the 'HyperMesh' model.
