Dear Sir,
I have carried out the tutorial on Friction Stir welding, But When I exported the model from FSW to Hyper extrude using *.tcl and *.grf file. The export was successful. But when I opened the model in H-xtrude, it showed an error message as
- - - Material NotGiven_Error was found. Skipping this matassign for comp_name (6 times) after clicking on OK it gave another Data Import message as
- - - Please verify the BC and material data. Import does not include Bearing BC
Kindly reply on the above error messages.
This tutorial was taken from Hyper Works 8.0 -
FSW - Butt Joint Analysis using Aluminium.
Thanks for the support
Regards
Sunith babu. L
