How to get the correct bistatic RCS file to import Winprop
弛 张
Altair Community Member
Hi all,
When using winprop to test RIS boost to indoor wifi signal, I need to import the bistatic RCS file into winprop. I built the RIS on the XOZ surface in FEKO according to the angle relationship in the winprop manual (Fig. 1), but the results obtained (Fig. 3) did not agree with the theoretical values; So I used the fascicle method to set up the medium (Fig. 4), and the results obtained were in line with the theoretical values (Fig. 5), but it seems that the hierarchical method can only be set in the XOY plane, and it seems that the theta angle of the RCS cannot be set in winprop. So how do I get a correct bistatic RCS, or how should I set the pitch angle of the RCS file I'm importing in proman.
Thanks in advance
