i m doing MBD in motionsolve,while doing it my contacts gets failed, i am using surface contacts(throu 2d meshing and then imposing it with my 3d model) with coulomb frictn off n taking impact contact.
kindly suggest sum procedure so that it wouldnt fail.also suggest methodology to select properties parameters.
