Hi everybody!
Trying to run an analysis I get the following error message:
*** ERROR # 173 ***
A dependent d.o.f. defined more than once in rigid element entry.
grid id = 217306
component = 1
This message is repeated 5 times with an increasing number for component for the same grid id. So the highest number for component is 6.
I can't find the failed element in the model. Looks like the grid id does not comply with the node id.
Now my questions are: What is the grid id and how can i find the failed element? Does the number for component comply with the d.o.f.? How can i solve this problem?
