TK GUI TUTORIAL
User: "Altair Forum User"
Updated by Altair Forum User
Hello, I am going thorugh the tutorial for the HW GUI TOOLKIT and I got stock when running it.
The example is as follows:
hwt::CreateWindow mytoplevel \
-windowtitle 'Dialog Title'\
-noGeometrySaving \
-cancelButton Cancel \
-acceptButton OK \
-acceptFunc applyFXN \
-defaultButton Accept \
-minsize 470 300 \
-post;
proc applyFXN {args } {
tk_messageBox -message 'The Createwindow function passes the \
toplevel window to the procedure listed so you must have args \
in the procedure. Args is $args';
destroy $args;
set recess [hwt::WindowRecess mytoplevel];
set section1 [label $recess.section1 \
-text 'Section one label '\
-justify left \
-anchor nw \
-font [hwt::AppFont]];
pack $section1 -side top -anchor nw;
hwt::AddPadding $recess -side top -height [hwt::DluHeight 4];
set frame1 [frame $recess.frame1];
pack $frame1 -side top -anchor nw;
hwt::AddPadding $frame1 -side left -width [hwt::DluWidth 4];
set fileSelection [ hwt::AddEntry $frame1.entry1 \
-label 'File Name' \
-labelWidth 15\
-entryWidth 42\
-listProc whenPressed 'dialogBrowse $recess' \
-iconName msfolder \
-iconLoc -1 2 \
-withoutPacking \
-textvariable filename \
-state 'normal' ];
proc dialogBrowse {args} {
variable filename
variable recess
set filename [tk_getOpenFile -parent $recess]
pack $fileSelection -side left -anchor nw;hwt::AddPadding $frame1 -side left -width [hwt::DluWidth 4];
set bWidth [hwt::DluWidth 50 [hwt::AppFont]];
set bHeight [hwt::DluHeight 14 [hwt::AppFont]];
set button1 [hwt::CanvasButton $frame1.button $bWidth $bHeight \
-command '[namespace current]::importFile' $recess \
-text import \
-state normal \
-takefocus 1\
proc importFile {args} {
tk_messageBox -title 'GUI Checklist' \
-message 'The file has been imported.' \
-icon info \
-parent $args \
-type ok;
pack $button1 -side left -anchor nw;
It is a very simple code that displays a window with a input box to select a file.
I get an error message when running it that says there is no such variable as recess.
Does anybody know where to look for the syntax of the getOpenFile command?
Thanks!
1 - 4 of 41
    User: "tinh"
    Altair Community Member
    Updated by tinh
    I tested and see it run normally!
    Anyway you can try again with variable '::recess' instead of 'recess'. This will link recess to global scope and you need not declare by 'variable recess'
    tk_getOpenFile is a tk command, you look for help in Tcl/Tk manual
    regards,
    tinh
    OP
    Thanks!
    You are right, it works fine in the script editor, but in the tutorial page it does not.
    Once I have completed the script it is not showing the radio buttons.
    Do you know what is missing?
    -noGeometrySaving \
    -acceptButton OK \
    -minsize 470 350 \
    -post;
    destroy $args;
    -justify left \
    -anchor nw \
    -labelWidth 15\
    -entryWidth 42\
    -iconLoc -1 2 \
    -withoutPacking \
    -state 'normal' ];
    variable recess
    variable filename
    set filename [tk_getOpenFile -parent $recess ]
    -text import \
    -state normal \
    -takefocus 1\
    -icon info \
    -parent $args \
    -type ok;
    hwt::AddPadding $recess -side top -height [hwt::DluHeight 7];
    set section2 [label $recess.section2 \
    -text 'Section two label' \
    -justify left \
    -anchor nw \
    pack $section2 -side top -anchor nw;
    set frame2 [frame $recess.frame2];
    pack $frame2 -side top -anchor nw;
    hwt::AddPadding $frame2 -side left -width [hwt::DluWidth 4];
    set labelWidth 17
    set entryWidth 15
    set entry1 [hwt::AddEntry $frame2.entry1 \
    -label 'Entry field label ' \
    -labelWidth $labelWidth \
    -entryWidth $entryWidth \
    -textvariable [namespace current]::entry1TextVariable \
    -validate real \
    -state normal \
    -withoutPacking];
    pack $entry1 -side top -anchor nw;
    hwt::AddPadding $frame2 -side top -hegiht [hwt::DluHeight 4];
    variable dropDownList; set dropDownList [list Red Blue Green Yellow ];
    set entry2 [hwt::AddEntry $frame2.entry2 \
    -label 'Combo box label:' -labelWidth $labelWidth \
    -text 'Red'\
    -entryWidth [expr {$entryWidth -2}]\
    -listVar fromPopDown noTyping dropDownList \
    -state normal ];
    pack $entry2 -side top -anchor nw;
    hwt::AddPadding $recess -side top -hegiht [hwt::DluHeight 7];
    set section3 [label $recess.section3 \
    -text 'Section three label.' \
    -justify left \
    -anchor nw \
    pack $section3 -side top -anchor nw;
    hwt::AddPadding $recess -side top -hegiht [hwt::DluHeight 4];
    set frame3 [frame $recess.frame3];
    pack $frame3 -side top -anchor nw;
    hwt::AddPadding $frame3 -side left -width [hwt::DluWidth 4];
    set rbl [radiobutton $frame3.rb1 \
    -text 'Option one'\
    -variable '[namespace current]::optionVariable' -value one ];
    pack $rb1 -side top -anchor nw;
    hwt::AddPadding $frame3 -side top -width [hwt::DluHeight 4];
    set rb2 [radiobutton $frame3.rb2 \
    -text 'Option two'\
    -variable '[namespace current]::optionVariable' -value two ];
    pack $rb2 -side top -anchor nw;
    set rb3 [radiobutton $frame3.rb3 \
    -text 'Option three'\
    pack $rb3 -side top -anchor nw;
    Best regards.- Edgar
    User: "tinh"
    Updated by tinh
    I tested it and see 2 radio buttons: 'Option two' and 'Option three'
    an error occurred with rb1 when you creating it, you miss writing it as 'rbl' (RBL) !
    regards,
    tinh
    OP
    Very good catch! Thank you so much!.-Edgar
