hello
i have mesh structure
how to create a group of nodes
thanks
If you mean 'set': Analysis -> entity sets -> entity = nodes
thank you
how to impose boundary condition on this group of nodes
Analysis -> constraints -> nodes -> by sets -> Voilà /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
i dont have on my panel constraints , i have this panel http://cjoint.com/?DJloCyNCbS5
Which User Profile do you use ?
I justly check Nastran, LS-DYNA, Optistruct,... the panel 'constraints' is there (see screenshots)
my User Profile is Radioss block 100 , i have hypermesh 12
voilà
I know nothing about Radioss. Sorry can't help you.
in RADIOSS profile:
GO to Analysis>> Safety>> Entity sets and create node groups/sets
hi
what is the difference between Belytschko-Tsay and QEPH
Can I create a group of constraints?
Hi Mark,
What do you mean by group of constraints?
You can create a node set and create constraints using the node set.
Is there any way to organize constraints in sets/groups? For instance, I want to group by 3 different constraints I have on the same node and then make a second group that has 4 different constraints on that same node.
I don't see a way to create a set for constraints/loads.
If 3 different constraints are completely independent the you can create 3 different load collectors but these load collectors can't be grouped.
It seams no way to combine constraint collector. But for load collector, you can use Card image LOAD or ADDLOAD to combine them. This way is very easy.
