Hi all,
I need some help about washer feature in HyperMesh. I have a solid with a hole, imported into HyperMesh from CATpart file. Is it possible to create a washer around this hole?
I did some effort, but in the autocleanup file, HyperMesh gives option for washer only in surface holes.
If I try to create washer around the hole after meshing the face containing the hole (from Utility -> Geom Tools -> Washer) by selecting the lines at the mouth of the solid hole, HyperMesh shows an error: The selected line is not a free edge.
Certainly, this line is a shared edge between the surface of the face and the surface of the solid hole, therefore: does it mean that HyperMesh washer is only for surface holes?
