Hello everybody,
I usually work in hyperform with applying motion to tools. Now the tool should apply a force. So I chose Kraft instead of Motion. However, the model will not run then. What can that be?
Thank you!
Hello everybody, I usually work in hyperform with applying motion to tools. Now the tool should apply a force. So I chose Kraft instead of Motion. However, the model will not run then. What can that be? Thank you!
hi can you give more detail about your case? Normally, take an example in the single action draw, the top die will be applied with the motion and the bottom binder will be applied with the force. For the binder, you can choose the force type as contant, linear or spring as you wished.
