I'm trying to model a simple model of a bending beam with a kinematic coupling. A single node is to be coupled with a surface and applied a load to, so the load can be evenly distributed to the part. I have used this tutorial here:
https://www.sharcnet.ca/Software/Hyperworks/help/hm/hmbat.htm?pre_processing_for_bracket_and_cradle_analysis_using_abaqus_hm_4340.htm
I followed points 7-10, but when I try to import and solve the input deck with Abaqus, the following message pops up:
WARNING: The following keywords/parameters are not yet supported by the input file reader:
*KINEMATICCOUPLING
The model 'coup' has been imported from an input file.
Please scroll up to check for error and warning messages.
The job 'coup2' has been created.
The job input file 'coup2.inp' has been submitted for analysis.
Error in job coup2: NODE SET ASSEMBLY__M4 HAS NOT BEEN DEFINED
Error in job coup2: A CONCENTRATED LOAD HAS BEEN SPECIFIED ON NODE SET ASSEMBLY__M4. THIS NODE SET IS NOT ACTIVE IN THE MODEL
Job coup2: Analysis Input File Processor aborted due to errors.
Error in job coup2: Analysis Input File Processor exited with an error.
Job coup2 aborted due to errors.
It seems as the coupling would not have been defined properly, but I cannot see where as I don't know how to activate a specific node. Also, the key word is apparently unknown, which is rather odd. I've attached the input file, any help/advice are welcome.
