Putting text from a loop in a variable
User: "mkress"
New Altair Community Member
Updated by mkress
Hi guys,
my script reads a document and afterwards manipulates every line of it. step by step, every line is written into an outfile.
'while {[gets $data lines] >=0} {
set outfile [open $path/report.txt a+]
if {![regexp {N/A} $field2]}      {
puts $outfile '[format $formatStr $a $b $field1 [format '%.1f' $dif_temp]]'
close $outfile
Now I want to put every lines in a variable, that I don´t need the outfile. But with “set” I have only the last line of the loop in the variable.
set var '[format $formatStr $a $b $field1 [format '%.1f' $dif_temp]]'
 Could anyone help me there?
