I wantet to fullfill a RADIOSS Analysis, but in the window i saw this Messages
ANALYSIS RESULTS :
ITERATION 0
Element # 58898, element type TETRA.
WARNING - Outside of recommended range: Face Vertex Angle = 13.734
lower limit = 15.000
Element # 58946, element type TETRA.
WARNING - Outside of recommended range: Face Skew Angle = 80.068
upper limit = 75.000
WARNING - Outside of recommended range: Face Vertex Angle = 5.2756
WARNING - Outside of recommended range: Edge Angle = 83.530
Element # 59048, element type TETRA.
WARNING - Outside of recommended range: Aspect Ratio = 119.26
upper limit = 100.00
WARNING - Outside of recommended range: Face Aspect Ratio = 119.25
upper limit = 50.000
ERROR - Acceptable range violation: Face Skew Angle = 89.039
upper limit = 85.000
ERROR - Acceptable range violation: Face Vertex Angle = 0.48047
lower limit = 3.0000
ERROR - Acceptable range violation: Edge Angle = 89.433
upper limit = 87.000
Element # 59069, element type TETRA.
ERROR - Acceptable range violation: Face Skew Angle = 86.931
ERROR - Acceptable range violation: Face Vertex Angle = 1.5366
ERROR - Acceptable range violation: Edge Angle = 87.900
Element # 59086, element type TETRA.
WARNING - Outside of recommended range: Face Skew Angle = 81.011
WARNING - Outside of recommended range: Face Vertex Angle = 4.7384
WARNING - Outside of recommended range: Edge Angle = 84.562
Element # 59107, element type TETRA.
WARNING - Outside of recommended range: Face Skew Angle = 79.895
NOTE : other similar error/warning messages were suppressed,
use PARAM,CHECKEL,FULL to obtain full report
WARNING - Outside of recommended range: Edge Angle = 84.124
Element # 59171, element type TETRA.
ERROR - Acceptable range violation: Face Vertex Angle = 2.6829
Element # 59259, element type TETRA.
ERROR - Acceptable range violation: Face Skew Angle = 87.300
ERROR - Acceptable range violation: Edge Angle = 88.021
Element # 59449, element type TETRA.
WARNING - Outside of recommended range: Aspect Ratio = 121.15
WARNING - Outside of recommended range: Face Aspect Ratio = 121.14
Element # 59822, element type TETRA.
WARNING - Outside of recommended range: Aspect Ratio = 101.03
WARNING - Outside of recommended range: Face Aspect Ratio = 97.136
*** ERROR # 2203 ***
Error(s) encountered during element check
***** Element Quality Check Failed - error limits violation *****
NOTE : To bypass element quality checks (except essential validity checks)
use PARAM,CHECKEL,NO. This may, however, cause very poor results.
Element Quality Check Summary
Total # of elements that exceeded acceptable range (error) = 1266
Total # of elements that exceeded recommended range (warning) = 2020
Acceptable range violations:
Element Property # of Acceptable Range Max. Viol. Elem.
Viol. Lower Upper Value type No.
TETRA Face Skew Angle 1243 -- 85.00 89.48 U 986099
TETRA Edge Angle 1219 -- 87.00 89.75 U 1000978
TETRA Face Vertex Angle 1265 3.00 177.00 0.26 L 314212
Recommended range violations:
Element Property # of Recommended Range Max. Viol. Elem.
TETRA TETRA Aspect Ratio 781 -- 100.00 312.47 U 1016050
TETRA Face Skew Angle 307 -- 75.00 84.99 U 75042
TETRA Edge Angle 689 -- 75.00 86.93 U 80474
TETRA Face Vertex Angle 1036 15.00 165.00 3.02 L 101293
TETRA Face Aspect Ratio 876 -- 50.00 218.96 U 314212
*** PROGRAM STOPPED: ERRORS DURING ELEMENT QUALITY CHECK.
what can i do now ?
