Hi everybody,
I need to use Comment Entries form Component-Cards to do a rename of Components.
Solver Template is Nastran.
It works fine so far with PSOLIDs but doesn't with PSHELLs .
I tried to get the information of the comments, but using :
hm_attributeindexarraylength comps $comp1 6 -byid (6 is the index) doesn´t work fine.
There are Comps with the information in index 6, some in 7 others in 5 or 8 or even higher!
Is there no fix definition ?
Does anyone know a more direct way to get these infos in HM8.0SR1 (all SA-Updates installed)?
Bye,
Florian
