Dear ALL
I can't read Abaqus6.5 odb file in Hyperview.
This is a abaqus6.5 connector hyperstudy7.0 case.
I want to re-solve,how could I do?
Error message:
1 Error: Out of memory in : Curve 1.
read().
*************** Log closed: 09/26/08 17:18:36 ***************
2 Error: Out of memory in : Curve 1.
read().
*************** Log closed: 09/26/08 17:18:53 ***************
3 Error: OdbError: The ODB file does not match with the ABAQUS 6.8 version
supported in HyperView. The ABAQUS ODB API distributed by Altair
contains 'abaqus_odb_upgrade' utility that can be used to upgrade
this file to ABAQUS 6.8 version. If you have ABAQUS 6.8 installed,
you can also run 'abaqus -upgrade -job <newFileName> -odb
<oldOdbFileName>' to upgrade it.
4 Message: Reader: ABAQUS ODB Result Reader.
Error loading model
Best Regards,
Jim
